as per the documentation, the djetor kit from memory ships with a 2 bar map sensor
this does not mean it will read 2 bar boost. its far from that, its actually 2 bar pressure, so vacuum and positive pressure
youll find the stock map sensor won't go past 1.3 bar (again from memory, the documentation states this) because its 1 bar negative, and 1 bar positive
so a 3 bar map sensor is probably what you need
They must have changed the sensors, my last five or six D-jetro's are all scaled to read to 2bar gauge pressure and they will all run only to load cell 20 when over 1.9bar.
That's been my experience as well
The 1.85 was just what my tuner said he ran out of sensor at on his and mine. 1.85-1.9 same same. He's getting a 3.5 bar aem map sensor (1 bar vacuum, 2.5 bar boost) and rescaling. I don't think rescaling is going to do any good if the sensor itself is pegged.
im not very famliar with all this stuff but are u guys saying a d jetro pfc wont be able to tune a car for 2bar of boost?
im running a race prepped head with a gt35r and was hoping for somewhat 25-30psi of boost.
this wont happen with a d jetro?
I'm not sure where that comes from? the ones I've seen measure a small amount of vacuum and will read to almost 2 bar of positive pressure. ie atmosphere plus 1.8-1.9 bar of boost. I can double check this but I'm fairly certain the ones I've played with read to near enough to 2 bar positive pressure.
also the djetro does not ship with any map sensor/s, you have to buy it/them separately. you also need to buy nipple/s and the harnesses. none of that stuff is included if you just order the Djetro power FC.
