I've never been a fan of them, all the ones I ever put in eventually failed and caused boost spikes as they cracked around the rim and leaked boost that should have been read by the gauge.
They pretty much do f**k-nothing as there isn't traditional "airflow" as it's part of a closed end system. All the ones I removed never had a spec of dirt on them.
I've deleted them from my setup to minimise places things can go wrong
yeah the cheap ones always seems to split where they're glued together and it's a pain. air does flow through though as the sytem is open to atmoshere as it bleeds off air through the solenoid. the good ones usually have the two halves screwed together and I haven't ever broken one of them.
I was talking between the sensor and the boost line...not the solenoid.
Yeah I've had bad runs with the ones that come with both the AVCR and Profec B
yeah obviously any gauge or map sensor doesn't really flow any air, but the key places to put them are to protect the solenoid. it doesn't hurt to have them to protect the insides of your map sensors either just from oil vapour etc too, as long as they aren't breaking all the time. the best bet is to put them in the line out of the way of heat etc. like for profec b for it's internal map sensor put it near the control unit so the filter is in the cabin not in the engine bay. you are right though it's unlikely anything bad is going to happen without them. I use them though.
Thanks Mate - PM replied and money transferred!
Much appreciated!
Peter
ok, well I'll grab to 4mm trust ones for peter, if anyone else want some let me know as I'm going to order them today.
  • 4 weeks later...
Hi Baron!
Received the two filters today - thanks alot! The quality of the filters is incredible, as you described they screw together, are not glued, and can be slightly cleaned if necessary.
Thanks alot for your help!
Will be finalising the install this weekend.
Cheers,
Peter
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
