Changing Metal Head Gasket For Rb25det
rych
 Share
Just a quick one, i have a rb25det series 1 that seems to be leaking so i've decided to get a metal gasket. Did a search turn out i got mixed results of using 86mm or 87mm. I've got a stock machine, and the bore size is 86.5mm, just wanted to ask if its okay to go with 87mm as these are abundant as compared to the 86mm out there on the market.
anyone?please?i'll even do sucky sucky on the webcam for you just wanna get the answer asap lol.
86mm is stock. 86.5 is 0.020" oversize. You want an 87. Ideally you get your bore size, but they dont make an 86.5mm gasket that ive ever seen.
What makes you think it "seems" to be leaking? Are you gettng bubbles and oily residue in your radiator at idle?
If your having overheating issues there is a LOT of other things to check before you go pulling the head off.
i dont have bubbles,oily residue or heating probs, just that there are oil residues at the sides joining the top and bottom end. Also the cylinder gasket seems to have oil at the sides too. I figured the stock gasket will only hold boost at the max of 1.2bar and i definitely wanan go beyond that, so a thicker gasket is on its way.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
