PICK UP ONLY
I have the following items for sale:
Cooling-Pro Type 1 Front Mount Intercooler Kit
Autobahn88 Silicon Radiator Hose Kit
Autobahn88 Silicone Induction Intake
Autobahn88 Silicone Vacuum Piping
All these items are for Nissan Skyline ER34. I have never used these items on my car they are brand new, everything is still wrapped and in there bags.
The intercooler core has been powder coated BLACK everything else is untouched.
Below are the details from the manufactures them selves:
Silicone Vacuum Hose 1pc
RRP: $20
Size (ID): 3mm / 0.12inch
Colour: Blue
Length: 5 metre / 16.4fts
Thickness: 2mm / 0.08inch
Application: Universal
Silicone Induction Intake Hose 1pc
RRP: $155
Car: Nissan
Colour: Blue
Application: Nissan Skyline R33 R34
Model: GTST R33 / GTT R34 RB25DET
This Silicone Induction hose connects between Air Flow Meter and Turbochargers.
The Hose delivers bigger volumn hence more air to the turbo. Moreover, Silicone materials provide longest durability and better outlook after installed.
Silicone Radiator Hose 2pcs
RRP: $100
Car: Nissan
Colour: Blue
Model: GTS GTT GTS-T RB25DET
Year: 1993 ~ 1999
The Radiator hose fits for Skyline R33 R34 Turbo version RB25.
Cooling-Pro Type 1 Intercooler Kit - Nissan Skyline ER34
RRP: $399
Kit Features & Contents:
- Bar & Plate Core
- 600x300x76mm
- Polished Piping
- Stainless Hose Clamps
- Quality Silicon Joiners
- Mounting Brackets
Below are the some pictures of the actual items:
Pic of the Induction pipe, radiator hoses' & Vacuum Piping.
Pic of the intercooler piping and fittings.
Pic of intercooler core [YES ITS BLACK]
There is a small dent on one of the pipes for the intercooler, it was like that out of the box.
There is also a small dent on the Core itself, not sure if that was done while getting coated with the black or like that out of the box.
The RRP adds upto around $670 and that's without delivery costs that i had paid.
Im asking for $500 for all items, PICK UP.
Im not looking to separate the items at this stage so selling as a bundle.
Contact & Pick Up Details
Roberto Gomez
Mobile: 0403 368 090
If you want to check out the items that can be arranged at either Eastlakes [2018] or Fairfield [3078] depending on whats closer to you.
Eastlakes from 6:30pm onwards for weekdays, Weekends anytime
Fairfield from 9am-5pm weekdays.
Feel free to PM me with any questions.
  • 1 month later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
