i got a r33 series 1 skyline 93 model...and im thinking of converting the gearbox from auto to manual coz im sick of driving auto..
Is it worth it?...how much would u think it cost for the gearbox plus labour??
any tips? i got a rb25-det engine btw
https://www.sau.com.au/forums/topic/275889-r33-auto-to-manual-is-it-worth-it/
There's more to the conversion than just swapping the gearbox, much more.
Sell your auto and buy a manual. Don't go converting a vehicle that came so widely distributed as a manual :whistling:
i just did mine, picked it up 2hrs ago. love it to bits. in the end the whole conversion cost me $2k installed... hoping to get some money back from selling all the bits.
$2k? dats alrite...but after seing ur other post it has side effects/problems but anywayz yea i should just buy a manual...god dammit why did i buy an auto LOL...the car looks good though
Nothing wrong with the auto gearbox ... just modify the valve body ...
Either a stage 2 shift kit or stage 3 full manual valve body upgrade
Stage 2 shifts are pretty hard and alot quicker than a stock gearbox ...
I have the stage 2 in mine and it has no trouble kicking the rear end out and im running a N/A R32 GTS RB20DE
I am also running a Series 2 R33 GTS-T Auto gearbox in mine
2k! goddamn! was 4k the last i checked. which was the price diff between auto and manual cars anyway. mates rates?
nah, bought the conversion off ns.com from a dude, then got a workshop to install it.
yeah it turned out that the manual conversion on r33's is a bit more involved than other nissans (32, 180sx, 200sx, silvia), in other cars you only swap over the auto loom to manual one, however r33 has different harnesses between auto and manual and you have to re-wire and make your own small loom. Its fairly straight forward from what the mechanic told me, just gotta know which wires to use and which ones to remove.
The car is running great again :down: loving the manual!!!
Edited by SkyHi_33
sure did mate! thanks for all your help really appreciate it ;)
goes so much harder with manual :) still keeping me over the moon hehe just need to swap out the dash cluster and were done.
Edited by SkyHi_33
yeh it depends how attached you are to your current car... selling mine and buying a manual one wasn't an option for me because ive already done a heap of suspension and brake upgrades to it and spent many long hours working on it, so wasnt worth pulling it all out and repeating the process on another car.
good luck with your decision tho! i think you will find that the 180sx is a lot more sportier and agile to the skyline but you will miss the comfortable interior and the inline 6 torque :P
Was gonna buy a new car but changed my mine..Its not worth buying a new car either especially if ur gonna buy from the dealers..The cars are expensive and paying finance is not worth it...
anyway hook me up skyhi i wanna do the conversion too! :D
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
