lol smells like a spam bot (seeing as he has the brand name he mentioned in his nick), but oddly its on topic and in the right section. haha has me second guessing. My guess is its a way to get Google search results hits when someone searches for "welding aluminium with a mig".
but back on topic, I'm thinking of buying a MIG, but wanna be able to do aluminium welds too. do I have to get one that's capable of really low voltages as the aluminium I wanna weld is pretty thin?
Shan, same smell i got from it haha - the thing that gave it away most was the automated template used, that worked on the other thread in the US
Alloy welding requires more amps than mild steel, but as VB- stated nylon liner is best practice along with the correct gas shield- depending on the mig you get, you could get a spool gun for it that holds the roll on the gun to stop binding in the gun.
so what are YOU doing on a US based Z forum craved? good tech/fab sections on there or anything?
can you still get those push-pull guns? havent really seen em around (bar the ancient ones floatin round the shop/at trade school)
I can weld down to 1mm fillet and butt welds at work, but that is on WIA 450 industrial machines with a 'softarc' setting. But that setting my only be an Incat program.
At home, I have a WIA 175 which I weld mild and ally with. Coiled steel liner for steel, nylon for ally. Use .9mm or 1.0mm ally wire with Argon gas, no mixes, just Argon.
Did I mention my trade is Aluminium welder / fabricator?? *lol*
Cheers, Greg.
  • 4 weeks later...
as above!! use pure argon and nylon liner. the liners usually dont last that long tho
i welded heaps of alum with mig but nuthin under 4mm plate
i would say a mig weld that thin would sit on top of the metal more than a tig weld which tends to "sink in"
that was my experience. btw i was using .9 and it welded 4mm up just fine
was on a unimig 165.
  • 2 months later...
Cheers, Greg.
how do you go welding steel with pure argon ive never tryed it but from what ive herd it doesnt penetrate really good if it works well i would love to no as ive got a mig and i just bought a tig and really dont want to have 2 bottles
thanks tim
  • 3 weeks later...
  • 1 month later...
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
