V35 Owners
gtrtech
 Share
^^^ yeah I frequently see a blue coupe parked at a bike shop on North East Road, Klemzig.
And sadly I have now seen 2 other black coupes like mine in Adelaide :( - I has a very custom plate, and the other a normal plate.
  • Replies 54
  • 3 weeks later...
lot quite a local '35, but spotted a sexy matt black V35 coupe in downtown Auckland yesterday. matt finish paint with a bodykit (Kenstyle front?), all black wheels, and super black tinted tail lights - would that make it an NZ All Black V35? lol
have seen a few V35's here in Auckland today, but noticed quite a few Libertys (Legacy) and Legnums driving around.
anyway, as the locals say, "kia ora" from NZ!
  • 3 months later...
Nightcrawler has reminded me in another thread that there aren't too many V35's in SA ... so how many active owners do we really have ?
rollcall !
(Andrew does this thread belong in the V series or the SA section?)
Nah since it is an SA specific topic I have no problem with it.
Kim's question was "ACTIVE" owners Brad :D .... in which case there are not many - Kim, me, Geoff and a couple of others that have briefly shown their faces :(
Someone decided to run into ours this week.
Now waiting on quotes.
And yes, it's worse than it looks in the pic. Panel is pushed in quite a bit.
Back in happier days
let a dark silver 350GT sedan drive past me on Holbrooks Rd an hour and a half ago - was surprised to see that it was a Series2 like mine (by the tail lights) same colour, front bar, etc. CC premium plates with a blonde lass driving it.
is kinda strange seeing your own car drive by! would have been weirder if i was actually in the V35 (was driving my other car at the time)
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
