V35 Owners
gtrtech
 Share
^^^ yeah I frequently see a blue coupe parked at a bike shop on North East Road, Klemzig.
And sadly I have now seen 2 other black coupes like mine in Adelaide :( - I has a very custom plate, and the other a normal plate.
  • Replies 54
  • 3 weeks later...
lot quite a local '35, but spotted a sexy matt black V35 coupe in downtown Auckland yesterday. matt finish paint with a bodykit (Kenstyle front?), all black wheels, and super black tinted tail lights - would that make it an NZ All Black V35? lol
have seen a few V35's here in Auckland today, but noticed quite a few Libertys (Legacy) and Legnums driving around.
anyway, as the locals say, "kia ora" from NZ!
  • 3 months later...
Nightcrawler has reminded me in another thread that there aren't too many V35's in SA ... so how many active owners do we really have ?
rollcall !
(Andrew does this thread belong in the V series or the SA section?)
Nah since it is an SA specific topic I have no problem with it.
Kim's question was "ACTIVE" owners Brad :D .... in which case there are not many - Kim, me, Geoff and a couple of others that have briefly shown their faces :(
Someone decided to run into ours this week.
Now waiting on quotes.
And yes, it's worse than it looks in the pic. Panel is pushed in quite a bit.
Back in happier days
let a dark silver 350GT sedan drive past me on Holbrooks Rd an hour and a half ago - was surprised to see that it was a Series2 like mine (by the tail lights) same colour, front bar, etc. CC premium plates with a blonde lass driving it.
is kinda strange seeing your own car drive by! would have been weirder if i was actually in the V35 (was driving my other car at the time)
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
