Your R33 is not Top Secret Gold, which can only be obtained from Japan.
No one knows the Top Secret Gold paint code... "Ooohhh" :P
http://www.topsecretjpn.com/stickers.shtml
around $500 a quart. or just take a sample of the paint to a paint mixer to match, they're kind enough to dip all the crap they sell in that gold so meh. That R33 doesn't look like the traditional top secrect gold anyways. bit too orangey.
Yeah i remember reading that too.
Well there is a R33 GTR in NSW, which I think is the one in the Top Gear Vid you posted, from memory, that R33 GTR was tuned and painted by Top Secret in Japan.
The owner bought it back here to AUS to re-trim the interior with Red seats and other bits.
Pity about the GT Wing as it looks shit and the bonnet looks terrible.
Ill just be a passanger with all you guys and girls and maby leech a little bit of the action off you all.
:D
You'll need a spare pair of undies if you end up in my car while im driving =b
The majority of females I know all likes BMWs & Mercs coz apparently they demonstrates that the driver is rich & has a higher social status than everyone else who isn't in a Merc or Beemer.
Also the Asian + Doctor equation comes into play here.
Hahaha thanks for the heads up, im sure they sell adult diapers somewhere.
For the vomit however, i cannot take any liability if you upholstery get ruined.
You're not going anywhere near my Recaros if you have a weak stomach.
ever.
interesting thing with the top gear or whatever... BUT massive thumbs down for the riced up gtr. hate the thing, looks like the owner should be driving a done up civic, or he probably had that before moving on to the gtr.
Edited by SkyHi_33
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
