Hi guys first of all i have a 1995 Series 1.5 Rb25det. Ive noticed for awhile when i have the car at idle say at the lights for some reason sometimes it wants to jump even tho i have the brakes on, when im driving around you dont notice it, its just when its pulled up sometimes. Any ideas besides vacuum leak as im trying to find it tommorow as i know i have a leak. (Stupid a$$ed Charcol Canister And Valve)
Also since i bought the car i noticed that when the Rpm tacho hits 2000rpm it goes down too 1500rpm before it goes up even tho i have the foot down, would any one had this problem, i just wanted to know it the gauge was dodgey if it is i dont mind :P.
Cheers Rob
BTW does anyone know if i go down to nissan tommorow they would be able to find me a vapor canister purge valve that sits on top on my charcol canister, because when i did hit boost i lost the rubber diaphram that was in there :laugh:
Edited by HoWiE_Au
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
