3 hours ago, toranarod said:
I know this is an old topic.
Is there any re manufactured replacement panels in Australia theses days for the strut towers. Anybody know of a supplier. Best re Rod
Best way is to find an old POS skyline and take it's non rusted pieces. It's been done before and will continue to be done until we run out of non-turbo automatic models. lol
A decent front cut chassis will do.
13 hours ago, toranarod said:
thanks that will helpful. they a good at what they do.?
yeah he does some really nice work! i believe the ones you linked are supplied by him to jdmgarageuk
  • 1 month later...
It all comes down to the life they've lived. If they've been well garaged they will have minimal or zero rust. The less time they've been in Japan the better too.
Obviously the further away from the ocean its spent its life will also have a major bearing on rust.
A car looking like yours I would say has lived near the ocean a lot of its life seeing the rust is under the bonnet and in between panels as opposed to exposed panels or under the vehicle.
I think you are totally correct. This is one is going to be my daily driver my fun car being a turbo and It was cheap for a GTT. I purchased the car knowing what was a head for restoration  . My other one is one owner since imported and has low Ks and been garaged for 8 years the difference in condition is chalk and cheese and will remain in the garage as a fine example of what once was.  The Gtt damage from rust and neglect is heart breaking and the rebuilding will be hard work. Working on a car is the only way to make it feel like its your car.
Edited by toranarod
I am only a weekend car fixer up guy just learned a lot of  DIY car repairs over the years. When I started unpicking the spot welds and saw the damage I got a little cold sweat happening this is a bit outside my pay grade. What fazed me was the top plate that needed replacing was under 3 other layers of panels. Just like the JDM guys in the  UK they need to be removed.
That link to the UK Restoration on the R33 was very helpful they have covered the job with so many great photos I was able to plan and get off cuts I might need. Thank you for the links to that page DaymoR32.
I almost purchased the new panels from them but I knew I would need more of the steel around that area and landed in Aus the top panels would be 600 dollars or more and I might f**k it up so best to go with second hand off cut.
Faaaark, that's brutal!
Yeah rust repairs are a slippery slope. The more you dig the more you find and the worse it gets!
I had a Datsun 1200 ute that I gave up on in the end. It was a bloody rusty nightmare that never ended!
No worries mate, i kind of had an inkling at what was going to be underneath when you asked for replacement strut tops and Steve does a brilliant job of documenting and showing the repair process!
8 hours ago, toranarod said:
the left side not as bad as the right
Yes, not as bad but still f'ing bad!  Not to be too much of a Danny downer but the thing that would scare me is that if its in there, its probably plenty of other places too.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
