Way back before I removed the first spot weld I spent a kings ransom on buying paints and chemicals for the job not being really sure what i would find and how deep i would need to dig.
This is available on eBay. I am in Vic and we have only been able to buy on line as all or retail is locked down
Sika Sikaflex 527 AT White Specialist Hybrid Car Body Sealant 300ml. Automotive.
https://www.ebay.com.au/itm/Sika-Sikaflex-527-AT-White-Specialist-Hybrid-Car-Body-Sealant-300ml-Automotive/173381054429?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
work as of yeasterday
Edited by toranarod
more information
The whole point of this work is RUST so I have been treating all metal surfaces with a zinc phosphate pre-primer metal etcher called RustBlast before paint priming with a welding copper primer. What do you gurus out there think about this as a procedure before i commit to the return of the panels?  I don't know what treatment to trust my car to.
On 10/21/2020 at 9:07 AM, Shoota_77 said:
Top job mate, well done!  It will be totally worth it in the end knowing it's all done right!  You'll be doing full body resto's on 260Z's in no time!
Yes I was a fan of the 260z 2+2 loved them. Did you ever see what happen to the Nissan Bluebirds?
wire brush, clean, then paint on some rust guard rust converter, then repaint in white rust guard epoxy enamel ?
then get a pair of those strut tower protector discs from JL in west australia, that stop the bar from cutting into the paint, or cut your own out
Edited by phelbas
Thanks, I was able to sand it all off with 240grit wasnt really that bad, I've rust converted the area.
Im going to try and respray that area tomorrow, just wondering if I can prime over the small bare metal patch and old paint and primer all at once?
And should I use etch primer or just normal surface primer be fine then top coat?
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
