Way back before I removed the first spot weld I spent a kings ransom on buying paints and chemicals for the job not being really sure what i would find and how deep i would need to dig.
This is available on eBay. I am in Vic and we have only been able to buy on line as all or retail is locked down
Sika Sikaflex 527 AT White Specialist Hybrid Car Body Sealant 300ml. Automotive.
https://www.ebay.com.au/itm/Sika-Sikaflex-527-AT-White-Specialist-Hybrid-Car-Body-Sealant-300ml-Automotive/173381054429?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
work as of yeasterday
Edited by toranarod
more information
The whole point of this work is RUST so I have been treating all metal surfaces with a zinc phosphate pre-primer metal etcher called RustBlast before paint priming with a welding copper primer. What do you gurus out there think about this as a procedure before i commit to the return of the panels?  I don't know what treatment to trust my car to.
On 10/21/2020 at 9:07 AM, Shoota_77 said:
Top job mate, well done!  It will be totally worth it in the end knowing it's all done right!  You'll be doing full body resto's on 260Z's in no time!
Yes I was a fan of the 260z 2+2 loved them. Did you ever see what happen to the Nissan Bluebirds?
wire brush, clean, then paint on some rust guard rust converter, then repaint in white rust guard epoxy enamel ?
then get a pair of those strut tower protector discs from JL in west australia, that stop the bar from cutting into the paint, or cut your own out
Edited by phelbas
Thanks, I was able to sand it all off with 240grit wasnt really that bad, I've rust converted the area.
Im going to try and respray that area tomorrow, just wondering if I can prime over the small bare metal patch and old paint and primer all at once?
And should I use etch primer or just normal surface primer be fine then top coat?
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
