thumpr Posted October 22, 2003 Share Posted October 22, 2003 i need a replacement motor unit for an r32 drivers electric window - its jamming due to wear on the plastic gear on the unit. does anyone know if any local models used the same part for the elec window? nissan quoted $538 for a new replacement ... Link to comment https://www.sau.com.au/forums/topic/27596-replacement-motor-for-r32-electric-window/ Share on other sites More sharing options...
Penfold Posted October 23, 2003 Share Posted October 23, 2003 I think i might be in the same boat. I was driving home today & when i went to wind down it didnt move & it made a funny crunching/whiring kinda sound. Then the window stopped winding - so it wont go up or down. Now the window still makes the high pitched noise when you press the up & down buttons but it doesnt move anywhere. Any advice on removing the door fittings & recommendations on whats wrong would be good. I'll look at it on the weekend. Thanks Pefnold Link to comment https://www.sau.com.au/forums/topic/27596-replacement-motor-for-r32-electric-window/#findComment-579833 Share on other sites More sharing options...
Penfold Posted October 30, 2003 Share Posted October 30, 2003 Hmm, after opening & shutting the door a few times, now it seems to work ok. But as it goes down is a bit "jarry" & when it goes up its "jarry" too. It's a little louder but when it hits the top of the door it makes a "GRRAAKD" type of noise as it slide sup & doenst stop properly. ? Any advice? new engine thingo for it Link to comment https://www.sau.com.au/forums/topic/27596-replacement-motor-for-r32-electric-window/#findComment-586535 Share on other sites More sharing options...
thumpr Posted October 30, 2003 Author Share Posted October 30, 2003 jsut got a new motor for mine from a 180sx, 135$. do yourself a favour and leave the window up until you fix it, you dont want to get it stuck when its down! Link to comment https://www.sau.com.au/forums/topic/27596-replacement-motor-for-r32-electric-window/#findComment-586663 Share on other sites More sharing options...
