Hey guys, I have a series 2 stagea neo engine of course, and recently i have noticed the engine light comes on and the car immediately starts running rough, usually on idle at the lights or something, i worked out that giving it the "boot" irons out the problem short term, meaning the roughness goes away, but maybe in a day or 2 it comes back. i have changed the O2 censor recently, so its not that.
I have done a couple of mods, and it never happend before them. 3" front pipe and cat removal, and pod filter. i cant imgine that these mods would have caused the problem, but any suggestions are welcome.
where could i take it to get the fault codes checked?
regards,
Rick
https://www.sau.com.au/forums/topic/275997-engine-light-coming-on-in-s2-stagea/
engine light and rough running, i'd say it could be your coilpacks on the way out, its a common fault. best way to tell would be as you said, take it to someone to get the error codes read. even though the engine check light has gone out the error code stays in the fault code list, so you can look it up.
you could take it to nissan, or any good mechanic shop should have a Carman or similar to read the fault code, just ring a few mechanics and ask if they can read nissan fault codes. another option is see if one of the guys on here with consult software lives near you and can help you out.
check your fault codes
i have just bought a consult port and software which arrived today to resolve all current and future CEL issues
Hopefully its woth the venture
replacing parts at random is a bit of a hit and miss affair
Edited by 910trx
Fault codes are on this site somewhere - a search should find them after a bit! Coils usually only break down under load so i would clean the AAC valve (tutorial in the skyline DIY) and/or check your plugs first (replace with coppers gapped to .8mm).
ok guys, sourced the problem, i took it to nissan and got the fault codes checked. it is the coil packs.. cheers for your suggestions.
now for the next question.. does anyone know of or have a set for sale?
as Chris has said, just get a set of Splitfire coil packs, they have been proven to be good and reliable. you can pick them up for around the $600 mark. maybe cheaper if you shop around. shoot over to the for sale section in these forums and have a look at a few of the site registered sellers, one of them might have a SAU special going for them.
Interesting, my stag does the same thing. Only happens on start up, sounds like it runs on 5 cylinders and the engine light comes on. I turn the car off and start it again and it fixes the problem. Might have to take it to a Nissan dealer and see if its the same thing. I did the spark plugs last weekend and the coil packs look perfect not 1 single crack on them :)
I had this exact problem only a couple of weeks ago i had full service done plugs and oil and the rest checked the fault codes as suggested in this thread and indeed it was coilpacks picked up a set off jjr for $400 and problem solved so much smoother im very happy with them.
i checked my fault codes and number 21 came up, nissan said it was coil packs, so i bought a set of used r34 turbo ones, reset the codes and put them im. but the engine light still comes on, what is fault code 21? and the guy i bought the coil packs off said they were good as gold, what else could it be???
fault code 21 is the ignition system, coilpacks are the usual suspects. ignition system problems can also include, and CAS, the wiring out to the coilpacks, or the PT's in the ecu itself.
firstly, change the coilpacks for a new set of Splitfires, it will remove any suspicion that its a coil failure. even though the guy you bought them off said they were all good, they are still second hand ones. you've got to remember that second hand ones are still around the same age as yours, and they seem to have failed. best thing when you are dealing with coil packs is to get new ones.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
