hi,
get on to any os-giken distributor. OS Giken make a cross cut gear set to suit the rb25det gearboxes that handle quite a lot of power, i am unsure about the shift quality with these gear sets though. Biggest factor would be getting someone very good to build the box, apparently manta racing services are good at building boxes? Just about all the big power gts-t's on this forum are still running stock boxes as far as i know though.
Jamie
https://www.sau.com.au/forums/topic/27602-gearboxs/#findComment-578165
yeah,
mine had 3rd completely gone on the cluster and the other shaft but it could just be that it was flat shifted at high revs, plus it has big turbo, big locker and triple plate clutch which all makes a big strain on tha box doin 6k+ launches.
Reco should be fine as long as you don't do anything stupid and someone good builds it.
Jamie
https://www.sau.com.au/forums/topic/27602-gearboxs/#findComment-578395
