  • Replies 57
It's called 'dosing' in the VL world, also know as 'flutters', but around here it's best described as 'compressor surge'.
It's the sound of the air bouncing off the turbine blades when the butterfly to the intake plenum is closed. Normally all this pressurised air get's released by the Blow Off Valve, but if you don't have one, it does that.
Different length, shape and designs of pipes make different noises...
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4673870
It's either a HKS Super Sequential BOV or some cheap ass BOV or like what others have said compressor surge.
HKS Super Sequential BOV = Wank (Only useful on highly tuned cars that are running a lot of boost and the stock one cannot handle it any more)
Compressor Surge = Say goodbye to your turbo.
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4673960
Is that the HKS SSQV BoV? I've been trying to convince a mate to buy one for his evo, but all the vids I've seen of it its a sharp, high pitched noise rather than the VL flutter.
Just curious, is "dosing" unique only to the VL, or is there a specific reason VL owners choose it?
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674172
Yeah either it's the HKS BOV or like others have said with the metal pipe.
Any turbo car can make the noise, it just depends on the BOV set up or whatever the owner does to it.
The stock BOV should not make any noise, at least no "Stu Tu Tu".
But if you put on an air pod, while still having your stock BOV, you will get a nice "Suction" noise then a "Choo" at the end (Only when on boost).
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674302
What the hell is that noise? I've heard it twice now, both times from VLs. Is it some tricked out BoV?
If you ask me I think it sound ridiculous. My girlfriend was in hysterics for about 10min as we drove beside this thing.
Thanks.
LOL! just search "VL turbo dose" on youtube,,theres thousands of videos on that stuff,,apparently they're a favourite with wog guys and their significant others
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674330
my ceffy doses like an athlete on the roids, but it comes from factory with no recirculation valve, and still runs stock boost on a stock turbo. all you have to do is take out the intake resonator and bolt in a pod and I get instant flutters.
GAGF if that's bad for the turbo, it came from factory like it and has run for 180,000 kms with no damage to the turbo or engine.
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674359
that is incorrect.
the only relation a BOV has to flutter/dosing is whther its blocked or not. the type of flutter/dose depends on the width, length and material of the induction pipe. the turbocharger does play a roll aswell.
all a bov does is hold the air trapped in the piping. so it bounces around and goes back through the turbo, for the turbo wheel fins to chop up and make a stuttered noise.
a SSQV HKS BOV has nothing to do with dosing....its just like any other BOV... but produces a whistle like sound when air goes through it. if you block it off, its the same as your OEM bov and every other blocked bov. does nothing special.
the Dose you hear on VLs sound like stupid dolphins or piegons as you heard.
they run a small metal pipe, no bov, and multiple bends to magnify thehigh pictched stuttered noise.
alot of the high powered veicles in japan and here automaticlly produce this sound as a side affect for high horsepower aplications but usally produce a much deeper tone due to larger turbos.
this is because piping is usally much larger due to larger turbocharges and dont run many bends.
although the title says HKS SSQV, its incorrect.
personally i hate the high pitched doses, which have been attached to wogs and VLs. but i am madly in love with the noise similar to the 650hp R34 GTR videoed above. would prefer it over a OEM "CHOO" or whistle anyday
my 2c
:P
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674583
the vl boys cut a gap in there intercooler piping to put there afm so that there is no restriction between pod and turbo.
using diffrent lengths and angles of piping gives diffrent pitch noises.
alot of the guys that i went drifting with on the track a while ago had it, sounds sick when your using your accelerator to control the slide.
https://www.sau.com.au/forums/topic/276031-stu-tu-tu/#findComment-4674589
    • Don't use "gasless MIG" (FCAW) you want to use proper MIG. FCAW burns a few hundred degrees hotter than MIG will for mild steel. It is a true ball ache for sheet metal. New MIG / TIG machines even have features like "Spot Weld" as well as "Automatic" settings. Plenty of people say for DIY home hobby, the auto machines are pretty good for 95% of welding. I personally, I'm a sucker for punishment and wanting to dial it in, and be able to adjust the machine. Mainly because I used to MIG weld for a living, and being able to tweak and tune things ever so slightly was my preference. Hence when I bought my ACDC TIG, it has all the adjustments for everything and no "easy" mode. Ha ha I have stick, MIG, "gaslessMIG" and ACDC TIG at home. Out of them, if you're doing mild steel sheet metal repair, and want to do mild steel exhausts, go MIG. If you're thinking you'll want to get into doing some aluminium stuff, or stainless steel, get an ACDC TIG with HF start. If you can, get one with a foot pedal too. My MIG machine is a UniMIG, and my Stick/TIG is CigWeld. If I were buying another machine, I'd buy another CIGWeld. Lots of people having issues with UniMIG, and them not wanting to cover warranty. Everything has to go back to UNIMig themselves. CIGWeld, I've had to use their warranty on my machine for a gas leak, they have repair centres everywhere, (contracted authorised repair centres). First repair place I used were hopeless, but the second place were amazing. Warranty process itself super easy, and second repair place was telling me CigWeld actually cover in their warranty, upto an hour of techs time to help you with your machine, and going through the settings and helping teach you the machine. UniMIG keep trying to get out of replacing motherboards on 12 month old machines.   TLDR, mild steel sheet welding, buy a MIG. my vote is CigWeld for brand.
    • I guess that's what happens when someone can't convert metric to freedom units to machine something. 😛
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
