  • Replies 57
i run the GReddy type s bov to atmo and its wound in to hard setting. It flutters up to three times if im just starting to build boost and back off (driving gently etc). Dont much know why how or what, but i do like the sound. For me the light flutter is ok, but the louder pchsshht is where its at when im up her. For that reason i stayed away from the HKS SSQ on the skyline.
Ive seen and heard a few vl's dosing and im of mixed opinion about it. one thing for sure it doesnt say hard tuned to me, it says hello ladies look at me im full sick....
All that said i chose the SSQ on my sigma to keep the noise down on gear changes. It's running short and large intake pipes so it's quite subtle but still doing the job. See how it sounds when i get to 18psi and if it's too invasive i'll go plumb back. With that car its all about less attention is better where skyline it's pose on.
R32 gtr 362RWKW no bov apexi filters and i can dose as good and loud as any VL and it sounds tough as like if it where in bathurst again, two turbos belching out sweet noise now thats where its at. And for those that say no BOV does damage thats bullshit 20k klms with -9 garretts and still perfect cond turbos.
cheers.
i love dose. i did an rb30 conversion and bought a vipec ecu so i could get rid of my AFM so i could get some better dose. ~$8000 later and i couldnt be happier. oh yeah, the car goes alright too.
Edited by SECURITY
thats confusing as shit.
Suction and dose?
Sound identical to me.
I've got one of them.. thats all i know...
Its sorta... suction... then... when i let go of accelerator... got the BOV and some of the suction letting out :S
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 馃ぃ馃憤   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
