hey guys i am new to the site so please dont laugh if this sounds stupid!
twice whilst driving on the highway higas signle has come on the dash? i know it means 4wheel steer but WHAT does it really mean? i have hads the car for 2 weeks and it has only done it twice and it was on the same drive? fomr my house to the local auto store
any help would be great
cheers
51ooo
https://www.sau.com.au/forums/topic/27616-higas/
I suggest you do a search on this forum for "hicas" and you will find out everything you need to know.
The only real way you can test out your hicas system is to get the car data steamed by a consult machine. It's the easiest, simplest way to find the problem.
I had problem with my hicas when I first got my car. The wire from the speedo to the computer had been disconnected meaning lots of things weren't registering with the computer (including the HICAS). There is also another problem with my HICAS being that when the car isn't doing hard turns (as in cornering), just driving along the freeway, my light comes on. It's because the connector in the steering wheel isn't making contact so the computer can't make a connection betwen the sensor and the computer. I found this out by getting the car data streamed. You can either get this done at a Nissan dealer, or a mechanic who has the machine. The only mechanic I know that has one is Gavin Wood Auto Tech who is at Labrador down the coast.
I'd suggest if you don't know alot about skylines or cars in general, take it to a mechanic/dealership that knows what they are doing.
https://www.sau.com.au/forums/topic/27616-higas/#findComment-578333
mine comes on when i am on the highway for about 20 mins (usually near the strawberry farm on the m1 heading down the coast). My steering wheel does not sit on dead centre - its at about 11 oclock which really annoyed me at first but i am used to it. I didnt wanna recentre it because i thought that it might screw with the hicas??? How easy is it to recentre?
https://www.sau.com.au/forums/topic/27616-higas/#findComment-578419
Very Easy
Just take the horn button out with a screw driver then undo the nut inside with a 19mm socket pull the wheel off (it mey need some force) once its off make sure the cable for the horn is at the top, And make sure your wheel has the hole at the top too.
Then put the wheel back on Straight.
Ok there is a way dot on the bolt and one on the wheel so its easy to centre it.
My problem was that the wheel was not a hicas one so i brought a aftermarket wheel and hicas adaptor.
Hope this helps
Dan
https://www.sau.com.au/forums/topic/27616-higas/#findComment-578666
Originally posted by Spooks_Skyline
isnt the hicas light coming on a symptom of the speedlimiter (180km/h) wire from/to the computer being cut?
As I said in my post, with my car, the wire from the speedo to computer wasn't connected and there for resulting in the HICAS, ABS, speed sensor (HICAS and ABS use the speed sensor to function) and the speed cut wasn't working. All because of this one wire.
When I had that problem, the light used to come on after a few minutes of driving. Everyone kept telling me to check the power steering fluid but that wasn't the problem.
I have a spare HICAS computer here if you want to check that out. I got it.... "FREE" lets just say :)
https://www.sau.com.au/forums/topic/27616-higas/#findComment-579396
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
