Hey boys and girls
I have found out the Format and Prices of the Endurance GP to be held at Richmond Kartmania on July the 25th which falls on a Saturday around 8pm.
so we need a minimum of 16 drivers for this enduro event to go ahead and deposit will be taken soon.
$40.00 per driver - 40 laps each driver 60 mins approx.
$50.00 per driver - 60 laps each driver 90 mins approx.
$60.00 per driver - 80 laps each driver 120 mins approx.
I am thinking of the $60 GP as 80 laps each sounds like a lot of fun.
So who is coming????
So far
1. Me
2. Dave (scandyflick)
PS all deposits to be recieved by Friday July 10th to confirm a spot....that is once i advice how much it will be most likely a $10-20 deposit and then pay the rest on the night :P
Edited by Krishy
https://www.sau.com.au/forums/topic/276214-gokarting/
  • Replies 174
you know you want to Damo...hehehe
its all good brother.....i will put you down on the list
1. Me
3. Damo (damo_r34)
4. Craig (craig_r33)
so now taking $10 deposits and then you cover $50 on the night....
Edited by Krishy
https://www.sau.com.au/forums/topic/276214-gokarting/#findComment-4676267
WOW very great response to this boys....
So far we got this...
1. Me + (2 - 4)
3. Damo (damo_r34)
5. ruby +1 (rubyrs4)
6. vu (typevu)
7. adrian (rad32)
8. craig (priess)
9. david (writeoff)
10. lex (youwish)
11. luke (skylineguy19)
12. Wayne (weezy)
13. Anthony (love_my_32)
14. steve (stevep)
15. luke (2FST4U.R33)
So by the looks of it we are having about 18 drivers ie 9 teams which is looking great atm
Taking deposit of $10 tomorrrow at villis for those who can make it....and for those that would like to do a direct deposit just shoot me a PM please.....
So it will be 80 laps per driver......lol ruby mate you are on for that statement.....and i am with craig that a carton of your choice is at stake if you beat me.....so thats a little side wager for ya mate.....btw there is no qualifying so it will be drivers named for their teams, them teams are given karts and then you do your formation lap and start the race after your formation lap...
ALL DEPOSITS TO BE TAKEN BY FRIDAY 10TH OF JULY......so if your deposit isnt in by then and we only end up with 12 drivers the format will change to a individual GP so please guys get the deposits in by then ohhh and also dont be ashamed to rock up on the day but cannot promise a race seat :P
https://www.sau.com.au/forums/topic/276214-gokarting/#findComment-4679400
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
