Anyone around Wollongong (South of sydney) that can install a Car audio system (the lot, head deck, splits front and rear, amps, sub, dynamat etc)
In a R34 GT-T 1998 Model.
Thanks in advance, as i asked around some electronic stores and they charge a ridiculous amount just for installation.
FHRX Studios .. don't look any further. They're NOT cheap but they WILL do an excellent job and won't damage your car in any way. Tell Marty, Denis with the black R34 sent ya :D
I only had them fix up some wiring and install dynamats etc in my doors ... don't have the moulah to do the next step. Just for approx. ref. I got quoted about $1800 to rewire the entire car properly with heavy guage wire, a custom sub enclosure, with a decent 12" subwoofer, 4 channel amp, installation and tuning (atleast 6 hours of work) etc.. it'll probably be a bit more if you need dynamat done as well.
Do it once do it right .. you don't want someone scratching up your interior or things blowing up or car rattling like an empty can after a cheap job.
Edited by Delta Force
I believe their hourly charge is $77 ... you might find cheaper eg. $55 ph but is it really worth it? If it takes 5 hours you only save $100 going to someone cheaper, who maybe doesn't have any clue as to what they're doing or doesn't care as much as Marty does.
You can save yourself some labour charges if you really have to by getting dynamat sheets yourself and installing them. It really looks simple, you just need a small roller (to make it stick good) and a couple of hours and you'd be done with the front doors.
As for gear ... they can supply anything you want and their prices are VERY good (not a big markup at all) I've compared some of the quotes I was given to current 'specials' at some other places and sometimes they were even lower.
I know very good chap in ENMORE (Sydney), let me know if this not too far so I can giveyou need his details
  Black R34 GT-T said:
Do you know how much they charge on install alone?
Im trying to find someone private so i might be able to grab it cheaper :D
why bother. if you are going to cheap out then you are only screwing yourself.
that said there are people in the sydney market charging $110/hr and dont have a clue..
food for thought.
FHRX Studios
i can vouch for marty and the boys , they will look after you
i did a amp install there and it was perfect , and the boys did a great job , even stuffer around it for 2 days until they sorted it to be 100%
you do pay a little more but in end you will be happy and problem free
