Hey guys, I've just got my car back from the tuners. I thought I'd share the results...
My plan from the start has been to keep the engine bay looking as stock as possible so the coppers can't pull me up for anything.
Car makes 252.7kW on 19 psi.
Details:
- Stock Internals
- Highflow turbo by ATP with R34 Housing
- S15 480cc Injectors
- Bosch 040 Fuel pump
- 600 x 270 Stealth style intercooler. It uses the return path of the stock cooler.
- 3" exhaust
- Stock Airbox with K&N Panel Filter
- Wolf V4 ECU
- MAP Sensor (for those who don't know, Wolf uses a MAP sensor instead of the AFM)
- Factory boost solenoid
The boost is controlled by the in-built Wolf ECU boost controller which uses the factory solenoid.
I haven't got any pics of the engine bay but it looks fairly stock - just as planned :D
Unfortunately, the stock BOV was leaking and even the mod to stop this didn't work so I've had to block it off for the time being.
Cheers all :D
https://www.sau.com.au/forums/topic/276244-just-got-the-car-back/
Thanks guys :)
I'd say EAS Performance done the Wolf tuning if I'm correct in saying that. Love their work.
Yeah, Vick at EAS Performance did the tune. The guy's a wizard when it comes to the Wolf.
Thanks guys :)
I got the turbo through Vick. He works with the ATP High-flow turbo all the time and said 19psi won't hurt it. I'm guessing the R34 housing helps. Johnnilicte, Vick highly recommends these turbos so you could give ATP a buzz and see what they have; I've heard the ATP guy isn't the nicest person to speak to so just keep that in mind :sick:
As for the motor, yes it has stock internals and I brought up the question of 19psi being ok for it. He said it's safe and even went to the effort of showing me through the tune and the slight tweaks he did to preserve the engine.
Having the car as a daily driver, I run it on low boost (8-9psi) most of the time and only chuck it on high boost when I feel like giving it a bit of a squirt. I don't go deca days and such so the car won't be 'hurting' and pushed to it's limit very often.
I've realised there's a lot of debate on how much boost to run for stock engines - some say simply, too much boost kills the engine, others say depends on how safe the tune is or a combination of both.
I was a bit paranoid at first but after Vick explained it, there's more peace of mind. I guess time will tell...
I haven't got a torque graph, but I was told the force at the wheels is about 6500N - I still haven't converted it to Nm.
Suprised its still running.
Why??
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
