hey guys} i have just went to see how fast my car is down a back street.
i have a r33 gtst s1. it is near stock except for turbo-back exhaust, bigger pod, heavy duty clutch and boost on 10psi. when i got the car about 3 months ago it seem heaps fast, now after a little hard driving it seems heaps slower.
the best 0-100km time i could get was about 7.27. accourding to other people they say they can get 6.2 etc.
does anyone know what is wrong or is this normal time. what can i do to fix it? help! :D
https://www.sau.com.au/forums/topic/276249-r33-gtst-slow-whats-wrong/
YOUR DOING IT DOWN A BACKSTREET... thats whats wrong... and ur mates little stopwatch isn't cutting it according to ur liking...
Go to a drag strip ya tight arse...
*EDIT* I appologise, ur a new member obviously. For your info, Skylines Australia does not condone any type of illegal activity on the roads... drag strip/skid pan/drift/track day is a different story...
Im sure this thread will be locked as it involves you asking questions about illegal behavior... perhaps editing the first post might be an idea..
As for your issue... what tyres are you running? that would be the first problem... traction getting the power from your engine to the ground... they make a big difference. you've said you have a heavy duty clutch so that shouldnt be the issue then....
honestly though, take it to a strip with some decent rubber, learn how to launch properly and im sure u'll be happier then doing dangerous stuff on the road... even if its a side street.
so who are these "other" people? the weakest link is usually you the driver. how are you timing it anyways?
now ask yourself this question, what is getting your car from 0-100 in 6.2secs on public roads really gonna prove anyways? honestly?
pay the $$ and get it properly timed on the strip if still want to prove something.
hey guys}
i have a r33 gtst s1. it is near stock except for turbo-back exhaust, bigger pod, heavy duty clutch and boost on 10psi. when i got the car about 3 months ago it seem heaps fast, now after a little hard driving it seems heaps slower. my tires on the back have like 10% tread, wouldd this affect the time by heaps?
does anyone know what is wrong or is this normal time. what can i do to fix it? help! :)
would changing the spark plugs and getting a service help?
i think 7sec for a GTS-T is pretty slow.
N/A supras can acheive better times than that.
Alot of things can come into play
worn tires is a possibility...
but id be looking at other things
have you had it dynoed? id give that a go and see what outputs you get...
umm has this question by the same person been asked Multiple times?!?!?!?!??!?!
Well if the car feels slower maybe something isnt right or you are getting used to it, Best to satisfy your curiosity and get it onto a Dyno and see what sort of health your car is in. But the time recorded as illegal as it was does seem very slow considering the car isnt 100% standard
LOL yeah,,theres a bit of double posting goin on :)
Anyway.. as i replied on another thread asking the exact same question..
how are your launches? and i definately agree with WYTSKY, keep it off the streets buddy, go crazy on a drag strip, i hope ur not a p plater..cops wud never let ur car see the light of day again if u got busted
yeah definately check it out on a dyno
mine was running slow when I got it, I didn't know
about it cause I went straight from an old laser 4cyl to skyline turbo six
without having driven any other higher powered car so I thought it
was fast and only found out when I got it serviced the guys at the shop
said that it was very slow compared to other skylines they'd serviced and
tested , they thought It might have been leaking boost or something, but
once they tuned it up and such I couldn't believe the difference.
Technically what he's doing may not be illegal if its in a 100kmh zone. But yeah, take it to a track or drag strip if you want to drive like a maniac.
Also if it doesn't seem as fast as it was you should have it serviced and tuned, maybe a compression test (??) and above all take a driving course to improve your driving...
So what your saying is that i could launch my car off a 2-step at every set of traffic lights and not expect to be fined if I only get to 60 before backing off??
Even if he is not speeding it is still classed as reckless driving
Is there a specific law regarding take off speed? I'm sure a cop could find something to fine you with if you did drive like that and you'd deserve whatever was dished out.
All I said was it might not "technically" be illegal.
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
