just build an air box 4 it outta sheet metal or like wise cuz it does crap without 1 anywayz as all its doin is sucking up all the hot air coming off ur engine...
i just whipped one up in a couple of days with a cai, cuz i got defected 4 mine as well lol, there aint that much of any gains in the NA but it sounds cool :laugh: ... if not just get a stockie n wack it on with a high flow panel filter, think i still got mine as well if ya still need it
Hi there,
I'm interested in getting that stock airbox off any of you guys, if you still have it..
How much would you like for it?
Just to confirm (I don't know much about cars :laugh: ) .. When I got my car, it has a greedy air pod filter. Now that I am going for a roadworthy, I've been told to remove that one because I have an intercooler, and apparently its not street legal to have both. What you guys have will fix my problem?
Cheers,
Val
Hi there,
Cheers,
Val
intercooler? turbo? air box for an N/A is different mate, you'll be best to post in the 'Wanted To Buy' section.
If you got defected for a pod you dont need to put your stock air box, just go to autobarn and buy a pod shield...cost like $20 i think, you can have a pod...just as long as its covered. i kno this because i had a pod and needed a RWC so dont bother going to buy a stock air filter.
I need to replace this:
http://web.aanet.com.au/val/R34/17.JPG
with the stock one...
Please let me know what I need..
PS: What does NA stand for? ... My skyline is a GTT (single turbo)
Cheers
Edited by ndev777
This is the Naturally Aspirated part of the Skylines Australia Forum, that being non-turbo skylines.
The airbox for a N/A is different to that of a Turbocharged Skyline.
http://pds.exblog.jp/pds/1/200901/22/86/b0147786_2154144.jpg
http://www.exblog.jp/blog_logo.asp?slt=1&a...86_22444747.jpg
Your best bet would be one of these: http://justjap.com/store/product.php?produ...=272&page=2
This will fit with your factory intercooler piping, and the box won't foul FMIC piping if you have a FMIC that has piping that runs over the radiator.
Sourcing a factory airbox and snorkel, and a hi flow panel filter such as a K&N, would easily equate to the same cost if not more.
ohhh now it makes sense lol... i reckon it would be cheaper 2 make up ur own shielding n keep the pod u got... i paid no more than 5$ 4 mine n its polished metal just scrappy stuff but it looks pretty damm good n does the job
oh yeh make sure its all bolted on 2 cuz they will get ya on that as well
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
