Ive been tryin to find a nice set of rims for my 33 n/a. i did find a set on tempe tyres, but they r only 17's ans dont come in 18's, which is wat i want to go for.
does any one know of any sites that have rims to suit n/a skylines (4 stud)?
cheers,
https://www.sau.com.au/forums/topic/276254-rims-for-na/
  • Replies 44
cheers,
http://www.stgeorgetyres.com.au/
http://www.tempetyres.com.au/
dunno if NSW have a tyre factory but yeah, try there too
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4676860
There are rims out there, you just need to know what you want and know how to find it.
Ditch searching from Tempe. What's your budget?
Something along the lines of these suit your criteria of 18 inch 4 stud.
18x8.5J+29
18x9.5J+29
http://page12.auctions.yahoo.co.jp/jp/auction/p140223242
Alternatively if you're dedicated you could do the turbo brake upgrade, and have better brakes with a larger variety of 18" wheels to choose from.
-Jimmy.
Edited by -Jimmy-
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4677251
Finding 4x114.3 rims isn't all that hard ...
Finding 4x114.3 pattern wheels to clear turbo brakes on the other hand is pretty hard ...
im doing the turbo brake upgrade on my R32 using the R33 gts-t calipers and rotors redrilled to 4x114.3 but ya need some huge offset wheels in order to clear the big calipers or ya need like 25-30mm spacers to fit them
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4677298
i have 17x9 +15's in 4x114.3 all round, clears the 33 gtst brakes on my 31. :)
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4677573
oh yeah, importmonster.com!
Rip off, their fees are ridiculous. Trying to search on that site doesn't show you half of what's on there most the time too. Using a translation of auctions.yahoo.co.jp is the way to go, and then get Jesse Streeter to get them for you.
www.jessestreeter.com !
Edited by -Jimmy-
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4678640
thanks guys,
i might try some of the places around newy, bob jane and all them.
my budget is about 1000-1500, im only an apprentice so cant afford all that much.
i have been thinkin about the 5 stub conversion and brakes and that, but a) i havent got the money for them b) i wouldnt know where to start to find them or put them on and c) this is my daily drive so it cant be off the road for more than the weekend.
i have a good idea of the style i want, these r on tempe tyres, but r for turbo'd lines.
either in shadow like this or chrome. have asked tempetyres but they cant machine them to find 4 studed lines
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4679247
look around for multi studs so if you ever do decide to upgrade brakes or sell its win win
yep..
you'll probably find most of the better size/offset rims are multistud anyway.. both the sets i've had that clear 33 brakes were.
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4679677
thanks every one for the inputs.
Line 3- they r mad rims but not the stlye im goin for, i must be hell picky haha
Hank scorpio- where can i find Work and Volt rims, i have seen Volt rims on some of my mates cars in sydney, they dont look to bad.
as for a picture, the missus reset the computer for some reason and she only saved her pictures, so i havent got around to takin any more, im pretty 100% sure it is the same as Line 3's skyline, but a light silver colour
https://www.sau.com.au/forums/topic/276254-rims-for-na/#findComment-4681262
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
