4x R34 GT-T Wheels, good tread on the tires, 4x 225/40/17s well above indicator. No camber wear.
R31 Ti wheels: 2x with bald tread.
S2 R31 bodykit. Skirts, Front lower lip and rear skirt.
R31 4.11 LSD diff. Good condition. Buy as it is in the picture
Chasing for the parts:
R34 wheels: $400
Ti wheels: $50 or a slab of carlton
R31 Bodykit: $250
R31 Diff: $300
Edited by kreyzgym
