They will not fit into the existing bracket... I know because I fitted one in my car last thursaday...
They are about twice the size of the stock pump, so you will need to alter the bracket...
also the top nut fitting is a different size...
AWESOME PUMP THOUGH....sounds sweet and works a treat.
Dan
I paid $215 dollars for my pump (part no 0 580254910-390)
You also need new fuel filter (for warranty reasons)....
I bought it online from www.onautos.com.au
The guys name is Trevor.... delivered to my door in 4 days.
My machanic fitted it and I helped...
Dan
if you are a hack machanic I dont recommend it..
If you get it wrong.. bye,bye motor....
Dont risk it... my machanic put it in for me for $60.... and that also included change oil,plugs, filters...... BARGIN, he looks after me....
Dan
bosch 390 can fit into the std bracket it you modify it though. i know some pumps are WAY too big and need a completely new bracket to fit...
is the 390 overkill?? im only after a 400hp pump... and with replacing the ful filter i just did that on my last service... do you need to replce it again or do they just say have anew filter present cos mines less than a week old!
ok i rang a performance tuner here in perth, they reckon no bosch pumps will fit the std bracket and to fit a 390 you would have to go for a surge tank setup....
i might investigate the possibility of using a GTR or VL pump, does anyone know of anyone whos used these?
I made a 044 pump fit in the stock bracket and it is the biggest pump they make. You have to moddify the bracket a bit and it only justs fits. Have a look at the 040 i think it is, it is a little smaller and is designed to be mounted in tank as it has the filter in the bottom of the pump, good for 400hp easy. The 044 requires the sock filter off the stock pump to be fitted to it. Get the biggest one you can afford to fit as you will be sure it will do the job, only paid $400 for the 044 so shop around to find a good deal.
Fuel pumps dont have a HP rateing !
They have a L/hr at x presure graph.
Bosch 040 Been useing a lot of these
Bosch 044 and these.
Bosch 975
975 is same as 044 but hand made and assembled and has threaded fittings, and is expensive !
The 040 and 044 can be made to fit in a standard GTR pickup situation, GTS-t same ??? i think so.
E
Adam you dont need a surge tank with the 390... all you do is buy some bigger fuel risistant tubing and by-pass the standard "small" fuel hoses in the tank.....
You will also need to put in NEW fuel filter with pump to keep warranty.....
Dan
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
