Hey guys,
I'm selling my 1995 model 200sx. I bought it 6 months ago. It was totally stock.
Straight away I took it to Japanese Motorsport to get the following done:
Brand New Trust T517z Turbo
Brand New GK Tech Stainless Steel Dump Pipe
Kakimoto Front Pipe
Kakimoto Cat Back Exhaust System
Brand New Greddy LS Intercooler Kit
Greddy Aluminium Intake Hard Pipe
Brand New K&N Pod Filter
Brand New Nismo 550cc Injectors
R34 GTR Fuel Pump
Apexi Power FC + Hand Controller
Brand New Z32 Air Flow Meter
R33 RB25DET Engine Fan (more blades for more airflow)
Auto Trans Cooler was converted to Power Steering Cooler
R34 RB25DET 5 Speed Gearbox
Brand New Nismo Super Copper Mix Clutch Kit
Car was tuned by Martin Donnon and made 200rwkw (1.4 bar) on his Mainline Dyno.
Also Fitted was:
Brand New JIC FLT-FAS Coilovers (adjustable camber tops. 10 step damper adjustable. 2 way height adjustable)
Cusco Front Strut Brace
Cusco Front Caster Rods
Cusco Rear Camber Arms
Nismo 2-Way GT Pro LSD (Adjustable)
Upgraded To R33 Rear Drum Brakes
Bride Brix Seat
Brand New Kenwood USB/CD Player
Blitz Dual SBC Boost Controller
The wheels are 17x8 +30 V35 Skyline Wheels ( I actually have a spare set so 8 rims all together!)
Exterior:
JDM series2 - Front bar
JDM series2 - Front bar extension
JDM series2 - Side Skirts
JDM series2 - Rear bar & pods
JDM series2 - Grille
Origin Boot Lid Spoiler
Aftermarket Sonar Headlights
Series2 Tail Lights
Series2 Front Guards & Bonnet
This car has done 148,000kms. It has not been taken to track and only used to get me to and from work.
I've decided to keep it neat and not too outrageous as my GTR already attracts heaps of attention.
Please note the paint is only average. This car owes me over twenty six thousand in only the 6 months I've owned and built it.
I want $18,000. This price is FIRM and sorry I'm not doing any trades this time.
I can be contacted on 0434100131 (Vinh)
or email: eski51 [at] internode.on.net
Location is Adelaide South Australia
edit : forgot to mention S15 steering wheel too :)
Please check out my R34 V-Spec GTR too!
http://www.skylinesaustralia.com/forums/R3...oo-t274961.html
Edited by geo11
https://www.sau.com.au/forums/topic/276321-s14-200sx-white-dailydrift/
  • 3 weeks later...
