Thought i would post to ask if any of you would like to pop over to a new section which has been kindly set up by the owner of the huge 'Skyline owners forum' (over 20K members) in the Uk and share information about our cars. In the UK we are using a lot of Australian tuning products like APS and Haltech so it would be good to hear your modified preferences with regards to body kits and performance. Also if you could post some pictures up of your rides in the picture thread im sure the UK owners would be thankful.
We could also provide a link back to this forum.
Cheers Tom
http://www.skylineowners.com/forum/forumdisplay.php?f=220
Edited by ukgt
https://www.sau.com.au/forums/topic/276333-v35g35-uk-forum/
got a cruise solution for yours yet? ( I make one.)
Nobody i know has got one yet however cruise control isn't a big concern in the UK as most of our roads arn't that long. I see you also do audio conversions, we have been looking for a way of changing the JDM set up so our sat nav/dvd controls are in English and how we can get the Sat Nav system to work in the UK .
https://www.sau.com.au/forums/topic/276333-v35g35-uk-forum/#findComment-4677819
were still working on that one too.......... :)
more than likely i dont think this will ever become a reality. So an aftermarket unit in place of the factory system is ideal.
https://www.sau.com.au/forums/topic/276333-v35g35-uk-forum/#findComment-4678222
not gonna happen anytme soon by the look of it. russian hackers are taking their time.
https://www.sau.com.au/forums/topic/276333-v35g35-uk-forum/#findComment-4678682
  • 2 months later...
no t yet but now im having trouble locking the car with the remote it will shut passenger door but not drivers side so im looking for maybe a new engine inmobiliser i have been quated 499oo for a viper fit
ted for my v35
https://www.sau.com.au/forums/topic/276333-v35g35-uk-forum/#findComment-4818661
needs an actuator for a start. from there its up to you waht you fit to it. if you are doing a specialist insurer then its going to need a Oz stds item.
where are you?
https://www.sau.com.au/forums/topic/276333-v35g35-uk-forum/#findComment-4818705
where are you?
im in yeppoon but if i have to i will travel to brisbane and also how hard or is it posible to fit the factory cruise control and dvd unit that fits this car
https://www.sau.com.au/forums/topic/276333-v35g35-uk-forum/#findComment-4819891
cruise can be done *easyish* if you are mechanically minded - I sell it as a kit and its NOT a factory item. I use modified factory buttons so it looks that way but thats it. DVD is along the same idea.
https://www.sau.com.au/forums/topic/276333-v35g35-uk-forum/#findComment-4819974
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
