Hey guys!
Good friend of mine has had her 32 stolen.
It's stock as a rock, black, very clean M spec r32 2 door.
Stock wheels, stock kit. Only mod was a JJR screamer dump and a sony cd player.
Rego is 587 LBG
It went missing from Harbour Town carpark on the gold coast between
1:30pm and 11:00pm.
Please contact me if you see it/know anything about it.
Car was not insured. Hoping to find it in one piece!
0427 282 562
Thanks.
Buckna
https://www.sau.com.au/forums/topic/276336-stolen-black-r32-gtst-m-spec-2-door/
wow, im there everyday. Ill look out for it. Send me a text if you get it back so I dont look like an idiot when I drop the dickhead who stole it and not know its you due to you getting it back lol
0402859795
dont kno if this helps - but i saw a stock as a rock black r32 driving down ferry ave (gold coast) on friday night with tas plates on it - might have swapped the plates?
it seemed to have an aftermarket bov..
dont kno if it helps but yeeeh :thumbsup:
car still not recoverd.
it was spotted on thursday night? (i think) Doing a robbery of a drive through bottle shop in ipswich.
Please keep your eye out.
Feel free to beat the sht out of the people driving it if you find them!
Flying back to the coast tonight before I fly to NZ tomo. Then will keep an eye out when I get back. Ill stock up on bricks too :P... ill try not to scratch her car, just whoevers driving it.
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
