You wouldn't be the first person to start a business from a small project like this. I always like to see people having a go. Good on you. Let us know the end weight and photos of vent cutout then all painted up.
  • Replies 47
hey buddy. im looking to replace my bonnet too. i cant decide between a carbon vented, or a fg vented item.
how stable is the fg item at highway speed?
have u had any problems? easily cracked etc?
Both items are fine, they are just as good as factory items if made properly. Never seem any problems with them cracking or anything, only problem i've seen is with carbon fibre bonnets when the clearcoat/gelcoat fades and turns a whitey colour and sometimes flakes off, usually caused by old age spending too many hours under the sun or just lack of care and it is purely cosmetic.
if you do add any more glass in, do it from underneath, for 2 reasons. 1: saves you having to smooth it out again, and 2: the more you add to the top, the further it is going to sit out from the lights and be higher than the 1/4 panels
there is no carbon fibre bonnet on the market that is as strong as the original metal.
you will find they are quite flexible and thats why you need bonnet pins to stop them lifting on the edges in the wind. They crack when they bend too much, often around the top of the radiator area. If it is pinned down properly it wont flex and will last forever.
fibreglass and carbon will crack or tear in a crash too, unlike a metal bonnet which will fold and bend.
don't go thinking they are stronger is all im saying lol.
here are some pics of what track speeds do to bonnets
i think it isn't so much because it is lighter, but because it is more flexible. steel is rigid so it can just have a single latch in the centre, but fibreglass is more flexible and at speed once a corner started to lift it would just keep on lifting, because the higher it lifts the more force it gets lifting it. if you have ever paid attention on the v8 supercars when they lift the bonnet, it flexes all over the place because it has no frame underneath it.
there are photos of mine and other cars with only two bonnet pins going down the straight at oran park at the sau day with the leading edge of the bonnets a good 10cm above the headlights in the middle. we now use more pins lol.
yes it is because they are flexible, not because they are light. take the frame off a metal bonnet and it will do the same thing. fg or cf will always be more flexible for the same amount of material
how do the r34 v-spec2 gtr's go with their carbon bonnets?
another way to help with flexing and lifting at speed would be to make it with piece of aluminium running along the front where you are going to pin it. bit late to put it it now, but if you were doing it again you could make the front thin, put the aluminium in then make it thicker so that the aluminium is closer to the top. if you had it closer to the bottom layers then there is more chance of the glass just tearing around it, but having it in the upper layers means the force is pushing the glass into it, rather than lifting it away from it if it's lower in the layers.
another thing that would help is spray bog, its perfect for what your doin because theres no highs or lows that an applicator can leave.. just block block block then prime
how much in glass and matting has it set you back? conpared to buying one ?
I dont think there are many diy carbon bonnets in oz.
the flexibility comes from it not being as strong as thick or strong as steel. Most glass or carbon bonnets will flex if you let them. put pins in and it cant flex
awesome thread. so is this going to be a street or race only bonnet. would like to know costs.
legally in vic im quite sure you have to have a metal bonnet, don't think fibreglass is allowed however unlikely they would notice.
Yeah will be for a road car, laws arent too harsh over here. Costs were about $50 for 5L of resin, $5 per square metre of matt, so about $15 - $20 worth, and $30 for body filler so it's been pretty cheap so far.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
