Hey all,
A while back i had an a-pillar with a pair of autometer gauges installed in my car. Everything worked and still does, great little gauges. But ever since the day they were installed, the boost gauge lights up at night like normal, but the air/fuel gauge does not.
I've never really thought about having it checked out, but now i'm just beginning to wonder whether it actually does light up at night. Basically I can only tell what is being shown on the gauge by the colour of the LED's between 'lean', 'stoich' and 'rich'. everything else is dark.
My question is: Does the gauge actually light up from behind, or is it just like it is now...dark. ?
https://www.sau.com.au/forums/topic/27639-airfuel-gauge-issue/
I used to have a pillar mounted autometer a/f ratio gauge as well. And I thought the exact same thing. It had a spot for a bulb, so naturally I tried putting one in but the internal circuit board seemed to foul any such attempt. I was left thinking that it was just a case of autometer reusing an existing guage cup assembly. There didn't appear to be any form of light guide either.
Those autometer a/f ratio gauges dont have any backlit, just the red, yellow and green leds. Anyway they are a waste of time and dont indicate anything as you cant calibrate them for your car and autometer doesent say in the instructions what a.f ratio is considered lean or rich!!
If you are gonna get a gauge get one tat actually tells you something usefull like an oil temp/pressure gauge.
Most autometer a/f gauges don't have a backlight except for the Cobalt series. They have a blue glow backlight that you can see the measurements at night.
Autometer a/f gauges uses some theoritical calculation to measure the a/f. But as it says in the manual there is never a perfect measurement just theory.
I got one too, but got is as a present so can't complain and it looks good at night!! hehe :)
It just works on 0 volts is full rich and 0.5 volt (i think) is full lean.
They are also designed to tap into the factory wire and take the signal from there. I was a little dubious about this so when i installed my guage i installed a second lamda sensor. This caused the gauge to only read the rich half of the spectrum.
That is the sensor puts out the full range signal, 0-1 volt, but the gauge, being calibrated to share a signal, can't get the top half.
Makes you wonder what having an AF meter is doing to the signal your computer sees!
BTW. On my old RX7 i used the same type of sensor and the microtech and af gauge shared the signal. The AF gauge worked perfectly but the microtech didn't seem quite right, it was fairly close though. As the microtech didn't use the signal for anything i wasn't too concerned
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
