Hey guys just got a project going on just looking to see if people know where I can find parts listed below or who can sell them?
- R34 Z-Tune Side Skirts (Carbon Fibre)
- R33 Door Cards (Carbon Fibre)
- R34 Front Splitter (Carbon Fibre)
- R33 Duck Wing (Carbon Fibre)
- R33-34 Front Guards
Basically this is a 33 that will be having a 34 front conversion done thats why there's difference on parts...
Cheers in advance
Dan
https://www.sau.com.au/forums/topic/276406-carbon-fibre-parts/
You know carbon fibre is illegal right(body panels etc).
You should probably think before you type such rubbish.
- R34 Z-Tune Side Skirts (Carbon Fibre) - NOT ILLEGAL
- R33 Door Cards (Carbon Fibre) - NOT ILLEGAL
- R34 Front Splitter (Carbon Fibre) - NOT ILLEGAL
- R33 Duck Wing (Carbon Fibre) - NOT ILLEGAL
The front guards might be an issue but are no more of an issue than people putting fibreglass gaurds on a skyline.
Edited by PM-R33
Fare enough, my bad
Nuh the conversion guards would be fibre glass not c/f as the whole cars being resprayed quad layer white pearlescent to show off the c/f accessories :(
The main c/f parts cops harass u about is the bonnet when people dont secure then properly as they are lightweight and under pressure can come off and its happened to my mate
An aftermarket fibreglass/carbon fibre bonnet is mainly illegal because you are replacing a main crumble zone of the vehicle. Since your car was factory crash tested with it's factory bonnet, having an aftermarket brittle carbon/fibreglass bonnet on it changes everything in the event of a crash.
Manufacturers rather cars be crashed head on, hence why cars are usually built to understeer. You have a higher chance of surviving a crash front on as there is more of the cars body to absorb the impact and distribute the energy. Obviously there are a lot of exotic cars with carbon bonnets, however they have been crash tested with them and built accordingly.
Edited by PM-R33
Actually our cars have not been crash tested, skylines end up with engines in the drivers compartment on impact serious enough. Hence why they are not legal in the US (unless reinforced) We dont have a legal requirement for crash tests. Just recommendations
But its more to do with quality and shattering of the fibres and harming people and the fact they like to bring in laws.
Edited by DECIM8
We can supply you with the Carbon Duck Wing, will be back in stock in the coming weeks. They are $299 and available to purchase directly from our website: http://www.psiparts.com.au/detail.htm?ProductID=R33S-DWNG-CF
BTW: PM-R33, that has to be the first intelligent post about Carbon Bonnets I have seen in a long time. For some reason I keep seeing comments about carbon bonnets turning into ninja stars and killing people within a 100m radius of the crash site. :)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
