Bit of a simple question, but im hoping a nice easy answer will pop up.
Ive got an rb30det in my cefiro and would love to mount up an oil temp gauge. I had great plans of welding the fitting into the sump, until i jacked the car up and realised I would near on have to remove the engine to do it.
Where have you guys mounted your gauges? I dont have an external cooler so unfortunately thats out of the question, + have no need to remove my engine for sometime. Im also not confident draining the sump and then drill it up without taking it off.
Any ideas???
Thanks
Byron
Edited by SirRacer
https://www.sau.com.au/forums/topic/276427-basic-question-re-oil-temp-gauge/
on your relocater it would read wrong...its needs to be on your block.
I always wondered if the block and relocator mounted sensors would pick up block temperature transfer too?
If it was in the relocator in the "hot" line, it would only be out by a few degrees if anything. Hardly heart stopping.
Where on the block would you suggest T'ing into then? This all just sounds a little extreme as if im tapping into the block, i really need to pull the engine out to do so.
Any other ideas?
Cheers
Edited by SirRacer
I use a sandwich plate between block and filter, which i then have the sensor in.... seems to work fine, and if you use a genuine nissan filter, its smaller than the repco etc versions.
I'd remove the filter as stated previously and use a sandwich plate and put the probe in there. You will get the oil temperature pretty much how you want it, right where the oil pressure should be read aswell.
Oil temperature gauge mounting: I'd mount it in a place that's not too hard to see, but somewhere where it doesn't stick out too much, as you wont be referring to it too often... :whistling:
Pretty much anywhere. Just Jap do them http://justjap.com/store/product.php?produ...=299&page=1
I used one on my old ITR. So if you get one, make sure you test fit it to make sure the senders clear everything etc. I cant rememebr what the bit on the RB block looks like, it might be fine any way. But the ITR the pressure sender had to sit in an exact place to clear castings etc, as they are bulky.
Also as i found, the blanking off bolts are tapered, and once they are in, they strip the sandwich plate out if you try remove them :)
So hand tight only my friend! Then crank it in once you know its all good and fitting snug.
Oh, and thread tape on the senders. Mine leaked a bit without it.
Edited by gotRICE?
Hi mate, i see your also from NZ. Where did you get one from here>?
i got mine from trademe, this is the one i got. http://www.trademe.co.nz/Browse/Listing.aspx?id=219755214
Fits perfect on my S2 25DET, but i MUST use a genuine filter (currently using nismo), as the repco ones are about 3x as big as a genuine one.
This is where i mounted my oil temp gauge too,
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
    • Did you pick up a manual cluster to remove the position indicator?  (Pretty sure the 34 has the gear position in the cluster, but it's been a while)
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
