I have been explained that my R32 gtst has a cat-back exhaust (Installed by previous owner).
I dont mind it, it sounds pretty good!
But then i've been told that fitting a 3 inch exhaust turbo-back, is going to give me a better, deeper sound and more kw's.
Is it worth the money to go change everything? And how much more power would I be looking at? :P
Cheers
https://www.sau.com.au/forums/topic/276469-exhaust-for-r32-gtst/
I don't think that you'll be looking at a gain worthy of spending the money to get a turbo back 3" exhaust unless you're going to add some mods further down the track to utilise the extra size increase. I'm assuming you have a 2 1/2" at present otherwise why would you go another 3" setup?
Hey Allen
Im pretty sure its 2 1/2" at the moment, but only cat-back.
What other mods would u be referring to?
If you were going to upgrade the turbo, boost, injectors, etc then you would be increasing the amount of exhaust flow which the 2 1/2" would be pushing to cope with. 2 1/2" with everything else stock is sufficient for now.
If you were to upgrade though, the exhaust, IC and intake are the first things that should be considered. This will give you a solid start to achieving your desired goals, this depends of course with your desired power levels.
