R33 Gtr Brembo Brakes Complete Inc Pads
Mike,
How do i tell if these will clear the racing hearts? Also will it be direct bolt on?
Hi Chris,
How much room do you currently have between the brakes you have now and the wheel? If you have an inch you should be fine if you have less it will be a tight squeeze and may require you to use a thin spacer for clearance. As for fitment you will need to see what size bolt your calipers are held on with as I have seen Stageas with both the more common 12mm bolt size as found on 300ZX, R32 GTS-T, R33 GTS-T or it will be the 14mm bolt size as found on R34 GT-T, R33 GTR, R34GTR etc. If you have 14mm you are laughing as it will be a straight bolt on with only wheel clearance being an issue. If you have the 12mm bolt size you will have to drill out the two 12mm diameter holes you have on each front stud axel to 14mm diameter and it will fit.
If you go to R33 GTR Brakes at the front you will need to use 17" wheels if you get defected so R34 GT-T stockies would be best I have a set you get borrow with new tread if you ever need them just give me a sms or call.
Hi Chris,
nigel, i think you've been mis-informed. r33gtr is 12mm so will bolt up to r32/r33 etc no worries. it's only r34gt-t and r34gt-r that are the 14mm bolts and require modding the stub axle.
chris, they will be a direct bolt on for you mate, i can't remember how much clearance the racing harts have - just check how much room between the back of the spoke and your current caliper and let me know what it is. even if you can't fit it, we know those wheels could do with 25mm spacers anyway :whistling:
Front and rear calipers and disks? Pics?
did you even read the first post mate? lol it says front only haha
chris, they will be a direct bolt on for you mate, i can't remember how much clearance the racing harts have - just check how much room between the back of the spoke and your current caliper and let me know what it is. even if you can't fit it, we know those wheels could do with 25mm spacers anyway :)
Thanks Mike was getting confused with R34 GTR and R34 GT-T that have the 14mm bolts don't know why I thought R33 GTR were the same sorry guys.
 Share
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
    • Talked to another R34 GT-T owner, he said bonnet of his car once fell and slammed from full height because of strong wind at a car show and nothing was damaged or broken, so I guess I'm just overthinking some things but yeah, just making sure I'm not damaging the car anyhow cause wanna keep it for a long time.
