This group buy was originally for SA only - but will now be offered to all of SAU.
Please note that there will be a freight charge of $15 to all states (other than SA - only because they have sponsored us for our official launch and dyno day)
But grab yourself a bargain guys!!!
I will PM people with the account details when needed :blush:
http://www.skylinesaustralia.com/forums/Sa...ou-t276058.html
Edited by MissR34
https://www.sau.com.au/forums/topic/276540-martini-racing-product-group-buy/
In conjunction with the launch of SAU:SA, Martini Racing have proudly offered us some products at an awesome rate for a once off promotional deal
Super Products Package
Martini Super Kool Organic New Generation Coolant
Martini Super Boost Road and Track Octane Booster
Martini Super Lube Synthetic Lubrication Supplement
Retail Value is $22.00 EACH
Martini is offering us to get all 3 products at $49.00 , including keyring and sticker sheet!!!!!!!
Now to the important fluid of all! OIL!
Martini are offering two different types for us:
Semi Synthetic 10w40 - (good for everyday skylines that arent driven hard) retail price is $49.00 , Our price is $41.00
Fully Synthetic 5w50 - retail price is $69.30 Our price is $58.90
1 Litre bottles also available....
Semi Synthetic retail price is $15.50 Our price is $11.40
Fully Synthetic retail price is $19.50 Our price is $15.90
DIFF AND GEARBOX
Sint 75/90 1 Litre Bottle - Retail $28.90 our price $24.00
BRAKE FLUID GS610 Brake Harder Faster Longer!
500ml Bottle - retail $42.00 our price $36.00
It is recommended that 2 bottles are purchased if you have not used GS610 before, one to be used as a flush, and the second as the refill
All prices included GST
All orders will be taken up until August 1st 2009, and will be delivered in time for dyno day for everyone to pick it while they are there!
So come on support Martini Racing just like they have supported SAU:SA and grab yourself some real bargains!! Remember this is a once off promotion just for us!!!!!!!!!!!!!
Just PM me with your details and what you would like, and i will be setting up an account for money to be transferred in
for more information on the products, please go to www.martiniracing.com.au
Guest
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
