please call on 0448812018
Item:TOYOTA SUPRA WIDEBODY MA70 7MGTE
Item Condition:GOOD
Reason for Selling:WANT SOMETHING DIFFERENT
Price and Payment Conditions:15K ono
CUT AND PASTE JOB
89 7mgte toyota supra [sLDWYS] plates not included
Specs:
Walbro fuel pump
550cc injectors
ARP head studs
Greedy metal head gasket
t70 turbo
custom manifold
50ml external wastegate with screamer pipe
3inch custom exhust
front mount intercooler with custom cooler piping and HPC coating over $2k
HPC coated plenum
xtream extra heavy duty 1800lb clutch brass button, chromoly flywheel $2k
greedy emanage ultimate ECU wired by etuned
HKS boost controller EVC4
Greedy turbo timer
15% tint
full reco radiator
monster tacho
boost gauge
nardi steering wheel
work equip wheels with yoko es100 as tread
full custom boot install with
1x 12" sub
1X 2 channel
1X 4 channel
1X 1000rms monblock
2X jvc 6 x 9's
custom door moulds for the front to fit 6" speakers
Got db at 135.7db (comp sub not included or monoblock)
the car makes 265.3rwkw on 12 psi and more to come
THIS CAR HAS NO PROBLEM GETTING MESSY AT 140KMPH IN THE WET
CONSIDER SWAPS
CALL 0448812018
IN NO RUSH TO SELL JUST SEEING WHATS OUT THERE, SPENT OVER 30K
PICS GO TO
SOME PICS AT http://www.beastclub.com.au/showthread.php?t=527
WILL COME WITH 8 MONTH REGO
ALSO HAS GENUINE DO LUCK TYPE 2 FRONT BAR $1500 (new)
AND ALL STOCK PARTS TO SWAP BACK OVER
THERE ARE THAT MANY EXTRAS TO MENTION JUST CALL ME.
CONS
THE CAR IS IN THE SHOP AT THE MOMENT AND HAS THE HEAD PULLED OFF NEEDS ABOUT $800 SPENT AND IT WILL BE GOING. I CAN FIX IF SOMEONE IS GONNA TO BUY THE CAR. THE DASH HAS A CRACK IN IT, I WILL REPLACE IT, AND I NEED A NEW HEAD LIGHT ASSY FOR THE RIGHT HAND SIDE
THE REASON I WANT TO SELL THE CAR IS I DONT HAVE TIME FOR IT AND I JUST DONT WANT IT ANYMORE
AND I DONT WANT TO LOOK AT IT AGAIN I NEED THIS GONE
CHEERS
ALSO MOST WORK HAD TO BE CUSTOM DONE, HAVE RECEIPTS FOR 85% OF STUFF AND ALL WORK HAS BEEN PROFESSIONALLY DONE
still more done to the car just forgot
https://www.sau.com.au/forums/topic/276544-supra-2673rwkw-on-12psi/
