i was gonna install the amp but i ran into strife.
Its a jap 2 din unit. i like it so i wanna keep it.
it must be old cos it doesnt have rca outs.
1. can i use the speaker outs as amp in's?
any issues there?
2. i can't find remote power coming from HU to power amp.
(no wiring diagram)
there's 2 wires pink & purple unutilized. would 1 of them be the remote power?
else where do i go ?
thnx guys
https://www.sau.com.au/forums/topic/276571-amp-install-in-r34/
Some amps will have a 'high level' input, this can be used to connect the normal speaker wires on the head unit to your amp. If your amp does not have these you're best to just replace the head unit, or get an amp that does. If you plug the speaker wires straight into the amps low-level inputs you will get an extremely distorted sound and risk ruining the amp.
The stock head unit probably doesn't have the +12v turn on wire for the amp, alternatively you can hook the amp to the "ON" wire at the back of your head unit (the wire that receives power when the ignition is in the ON position). If you look around google/sau you should be able to find a legend that describes what color wires do what.
You can use a multimeter or light tester to confirm.
Edited by nicr4wks
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
