Hi Guys,
Buying an Apexi AVCR very soon.
Just want to know if i can hook up an external switch (i.e. not by pressing a switch on the avcr face) to change between hi and low boost?
My idea is to have a switch on my dash which allows me to run low boost, then when i punch this switch the AVCR switches to high boost setting.
Does anyone know if this is possible?
Cheers
https://www.sau.com.au/forums/topic/276576-apexi-avcr/
Excuse the incorrect use of language, but you dont want to use a missile switch. The AVC-R has two boost settings so yo ujust go to the setting you want to run. A missile switch is a two pole( Language???) switch . You want a sinle contact button so that only whilst pressed it will complete the circuit thus giving you the scramble
I have a button on my old steering wheel for it. Though i never really had enough power to justify using it. I actually used it to drop boost with the scramble feature. So when launching in 1st gear i only had 8psi then in the higher gears i used to use the normall Setting B high boost setting of 15psi on my std turbo. Like i said never really had enough power to justify using it that way, maybe make use of it now that i have more power but i dont run it anymore :(
https://www.sau.com.au/forums/topic/276576-apexi-avcr/#findComment-4682595
whats the point? why not just tune the car for the maximum possible safe boost you can run
and use the avcr tuning ability to curve the duty to correct wheelspin etc
most people break things when their car is setup for a safe level
and they have a switch to go higher "for short runs"
if you run higher, why not run higher all the time
https://www.sau.com.au/forums/topic/276576-apexi-avcr/#findComment-4682608
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
