Just searched and read that...one last quest 2door or 4 door r32? thanks mate
the shaft will not bolt up, you use the rear part of your auto tail shaft and the front half of the r32 manual then you need to change the the bolt pattern by undoing that size 26 bolt so they will bolt up
https://www.sau.com.au/forums/topic/276614-cefiro-quests/#findComment-4682464
Also.. my car had a manual tailshaft to begin with but the unijoint was buggered.. (woo regency!) So I managed to find a 32 skyline tailshaft, not sure if it was a 4 or 2 door, pretty sure it was 2, unbolt it and switch it with the one already on the car. Worked a charm... :(
https://www.sau.com.au/forums/topic/276614-cefiro-quests/#findComment-4682623
