Hey guys,
Ive done a search and cant really find someone whos had the same problem. My drivers side window works fine going up and down, but the problem being that it stops at the bottom with about 3inchs of the window still exposed, kinda looks like the rear windows in commodores how they dont go all the way down.
I've pulled the door trim out and had a feel around the whole bottom edge of the window and played around with it to see if theres anything blocking its path, but it all seems fine, it doesnt seem to be hitting anything thats making it stop.
Car is a R33 series 2
Any ideas?
Cheers
Edit: Just had a better play with it, it looks like the curved gold gear with the teeth it uses to go up and down runs out of teeth and thats why its stopping, so basically its running out of teeth before the window is fully down. It probably only needs about 3-4 teeth of adjustment, so how can i rotate that wheel to adjust it without the window moving?
Edited by Sparky206
https://www.sau.com.au/forums/topic/276665-r33-power-windows-drivers-side/
Hey guys,
Any ideas?
Cheers
how you doin mate?
if you move your gear up to 3 - 4 teeth, you gota be removing all the window assembly to expose the motor.
its not too hard to take that out. just make sure you have somebody to hold on the glass.
if you have some Q's regarding this, feel free to pm me..
how you doin mate?
Thanks mate, still having some issues, ill shoot you a pm :bunny:
