i'm in need of some help with my r32 gtst
the steering has been heavy since i've purchased the car
firstly i put in a lock bar and removed the whole hi-cas system
then i changed the p/s pump and the steering rack
still has heavy steering
can anyone help me?
would really appreciate it if you know what the problem is
Cheers
Edited by DFAULT
https://www.sau.com.au/forums/topic/276730-heavy-steering-r32-gtst/
Did you remove all the electrics for the hicas as well? The hicas module controls the power steering assist, so if there is a problem with that, or if it isn't even there anymore, the steering will always be heavy.
If the hicas electrics are still in there and working, did you reconnect the solenoid on the steering rack when you changed it out? Does the steering start off light and then go heavy after a few minutes? Why did you change the rack and pump anyway?
Same prob happened with mine last week. HICAS has been removed for years with no problems but now steering starts off very light for approx 1 minute then goes heavy. Have not checked it out yet but if someone has experience with diagnosis then I'm all ears!
Possible stuffed solenoid on rack??
Edited by 321 GO
I left all the electrics for the hi cas
i disconnected it but it still has heavy steering
i plugged and unplugged the solenoid on the steering rack but did that nothing
i also plugged and unplugged the hicas unit in the boot but that did nothing
the steering is constantly heavy
i changed the rack and pump thinking that it would fix the problem, but i guess not
could there be a blockage in the lines?
i also get a weird noise when i move the steering wheel to a certain point, sounds like air coming out
any ideas?
any ideas?
Ha ha. I get the same noise. Thought it was just extra noise being allowed to travel up the steering column after installing an alloy steering block in place of the rubber one.
Where is heller44? Looks like he had some answers!
I've been playing in the red dust up north, no net access for monkeys up there.. only flew back in tonight.
I reckon you both have very different faults to each other, andrew yours looks to be a fault condition with the hicas unit, so you need to do a diagnostic on the hicas, look in the tutorial section for the procedure on how to do it, it is a pain to get it right but you should be ok.. count the flashes and work out what part of the system is faulting.
Dfault, yours isn't even starting out and then faulting, probably throw a multimeter on the pins for the solenoid on the rack and see if you are getting any voltage there at all. Possibly where I would start.. nice easy check anyway. Once that is done you can go from there and see wether it is mechanical or electrical.
i have this same problem in my cefiro
non hicas model
on the drivers side i still have this solenoid looking thing with 4 hoses ( i unplugged that )
then i have this senson down near the drivers wheel ( i thought could be a speed sensor that adjusts steering tension at high speeds )
and lastly i wound the nut out on the rack ( adjusting one )
done all that at same time and my steering is slightly better lol
just dont know what one made difference, its still heavy as thou !
Thanks heller44!
No HICAS globe in the dash as it was taken out when I removed the HICAS system many years ago (rack, oil lines to front etc).
Now that I think about it I'm sure my speedo stopped working at the same time. Would it be fair to say this could be my problem seeing as the steering appears to be speed sensitive? Honestly was not aware of speed sensitive steering in R32 and thought that as the R32 uses a speedo cable it would not be able to have a speed input to anything else on the car. Would be awsome if I'm wrong and my inoperative speedo could be causing my dramas!?!
*facepalm...
no speedo, no speed sensitive steering.. sheesh. mechanical cable drive from the gearbox sender to the cluster, built into the back of the speedo itself is something like a tacho generator that transmits a speed pulse to both the hicas unit and the ecu.
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
