URAS posted up an interesting single cam RB30 that ran Toyota supercharger and a GT35. Have a search, i think it could be an interesting setup on a decent Rb20. Only thing is you would want to be a bit of a timkerer, or at least your mates so that the cost of doing it could be kept manageable.
Bt based on the URAS setup i am guessing your 300rwkws RB20 would be more responsive then my 260rwkw RB20 running a smaller turbo.
I would sell the fact that there isnt a real reliability concern at 260rwkw for an internally std RB20, but at the sort of power a GT35 will make i think you would be going into less tested water for reliability and a std engine :)
