Gday all
I am looking at getting a ebc in a couple of weeks and not to sure which model/brand to get. I dont want any thing to over the top, just something that will hold boost
with out any spiking or drop off.
Can you just get a one setting ebc or are they all 2 stage?
What is every one using and do you have any problems eg spiking with them?
Cheers
https://www.sau.com.au/forums/topic/276752-electronic-boost-controller/
Well I can't say which is the best because i haven't tried them all but the Jaycar EIBC works perfectly for me and is cheap for an electronic boost controller. It has precise control and you can build boost as fast as you want and hold boost at your chosen setting for as long as your turbo can make it. It has two settings but I only need one setting so i have put the same map on both settings in case someone switches over to the other one. The only drawback is that it comes in a kit form but you may be able to buy one already assembled. There is a comprehensive thread in the DUY section.
+1 for the IEBC, but without the spelling errors :)
i'm also running the Jaycar IEBC in my stagea, works really well and hold boost perfectly, after about a week of street tuning i had is sitting where i wanted it. i brought one that was already assembled and i just had to wire it in so i cant comment on how easy/hard the assembly is. i went for the IEBC because it was like 1/6th the price of anything from japan at the time, and works with the stock boost solenoid just to keep things covert.
and i did run a Greddy Profec B Spec-II in my 32, it also performed more than well enough for what my setup was. i think it comes down to your budget, any of the good name brand boost controllers eg Greddy/HKS/Blitz are good, and i dont think you will notice any difference between them on a street driven/setup car.
+2 on the GReddy Profec B spec II. I'd heard nothing but good things about them, and since having one put on my car I have to agree that it's very stable. With a bit of fine-tuning of the PFC on my car, I get almost the same amount of power on 7psi (low boost) as I used to get before the EBC install when it was on 10psi. On high boost now (10psi), I have about 18kW more than before the EBC was installed.
The best thing is that I have the same power as before (or more on high boost), but with a much more progressive boost curve and more torque accross the whole rev range.
also one more for the profec, its smaller front makes it easier to put in a position you cant see from outside the car. ie, theives dont see it. the id3 has a largish LCD and can be quite visible from the outside unless you hide it
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
