hi guys
car was wreaked by some idiot that ran a stop sign :) now i have all the goodies laying around!
RB25DET NEO with gearbox, wiring loom stock computer and stock turbo (no injectors) 80,000km $5000
Trust Tdo6 25g turbo-kit comes with manifold, turbo 48mm trust external gate with screamer pipe, all stainless cooler pipes, braided lines, turbo beanie, trust foam pod and dump pipe (was slightly bent in the crash) only 7000km old zero shaft play
$5000
680cc sard injectors (top feed) 7000km old $900
nismo 2way diff 5 bolt suits R34 or S15 4000km old $1200
Nismo twin plate clutch with light weight flywheel 7000km old $1200
splitfire coilpacks suit NEO 20,000km old $550
bride race seat with rail to suit R32 gtr or R34 excellent condiction $500
Z32 afm $250
walbrow intank fuel pump $150
r34 greddy pillar holds 2 60mm gauges $130
r34 adjustable lower control arm fronts 500km old $140
R34 strut bar $100
stock intercooler $50
stock r34 NA rims 150
r34 stock seats full set $200
after market radiator $200
some Pricers are slightly negotiable but any low ballers will be laughed at.
this is good stuff first persion with the money in hand gets the item i will only hold an item if deposit is taken.
Have fun
pm me or call/text me on 0433708054 Please not in the middel of the night
parts are in Wa and i am happy to post at buyers expence for some of the items
cheers
Ryan
pic will be up soon
https://www.sau.com.au/forums/topic/276762-450hp-r34-neo-goodies/
  • Replies 41
no sms received but i am happy to send radiator
clutch is still between the motor and gear box hope to separate some time this week
motor is for sale as a hole but if you find a buyer for the bottom end i will separate
Edited by sickr33
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
