Hi guys,
I mostly post on the wrx.com.au forums, but have just registered here, as I'm looking into getting a R33 or something, as a daily driver, and getting rid of the WRX.
Just time for a change I guess...
1998 WRX with a V6 STi front bar/lip/headlights/grille and foglight covers....but a bit over it.
Anyway...just a short introduction...will be around for a while, and post my car in the for sale section...see if anyone would be interested in a swap??
Cheers,
MC
https://www.sau.com.au/forums/topic/276783-new-member-here/
amen, 20k +
My logic was for 5k extra i could get a 33 GTR.
So i did :D
With my tightass logic I figured I could pay 5k less and get a 32 GTR :P
Seen a few nice ones for around the $14k - $15k mark. Unfortunately that's still too much for Mr 'minimum wage' here. :P
https://www.sau.com.au/forums/topic/276783-new-member-here/#findComment-4684242
Hi guys,
Cheers,
MC
Welcome mate,
Nice cars WRX's apart from their gearboxes that is. Skyline is much different, talking from personal experience. They both got goods and bads. Are you after GTS or GTR?
https://www.sau.com.au/forums/topic/276783-new-member-here/#findComment-4684898
Welcome mate,
Sta ima Adise, jebo to hljeb??
kako Jasko's Rexy ide?
and yeah...I'd probably be after a GTS for now...R34 GTR next year sometime hopefully
https://www.sau.com.au/forums/topic/276783-new-member-here/#findComment-4685049
With my tightass logic I figured I could pay 5k less and get a 32 GTR :D
Seen a few nice ones for around the $14k - $15k mark. Unfortunately that's still too much for Mr 'minimum wage' here. :thumbsup:
Well stop spending ur "minimum wage" on hoes and drinks as suggested by ur profile pic lol
https://www.sau.com.au/forums/topic/276783-new-member-here/#findComment-4685236
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
