hey guys
just a question if i replace my rb20 redtop with a rb20 silvertop or even might be thinking of a rb25 (engine, gear box, ecu & loom) will i have to get the engine tuned to suit my hr31 passage if it comes straight out of a running r32? or will it still run fine?
also are there any mods i should know about to do the conversion?
cheers for the help guys
tune on the stock ecu will be fine. tis a bit rich but its fine.
its fairly straight forward. trickiest part is usually the wiring, but theres only a few wires. theres a guide on www.r31skylineclub.com somewhere
I would be using the loom and ecu from which ever motor goes into the car... and at the moment there is an RB25 from an R32 being sold by Phantom32 or something like that for 1500, and a mate paid 1200 for a silvertop recently... which is better value :)
can i reuse my original loom thats in the car already? for either a rb20 or rb25??? or are they both different?
cheers
use the loom to match the motor. when you buy an engine package the loom should still be all hooked up, drop it in the car like that and feed the loom through the passenger side guard area into the passenger footwell.
Removing the loom is easy. Take the passenger side kick panel off, disconnect the ECU and take out the ECCS/Ignition relays.
Then you can feed the loom back out through the firewall and into the gaurd, then pull it through into the engine bay and remove. Silvertop loom is just the opposite, connect it all up to the engine then feed the ECU connector and relays into the gaurd first, then into the car.
The wiring is straight forward, check out the guide on r31 forums or PM me as I have done a couple before.
ok thanx heaps mate
i take that as the looms are different from the redtop to silvertop?
will pm you if i get stuck thanx heaps
Yes the looms will be different, sensor types/locations vary. The major difference is between NICS and ECCS motors, but there are even differences between redtop ECCS and silvertop ECCS.
Good luck PM me if you get stuck.
  • 4 months later...
Hi everyone. I have just bought a hr31 and wanting to convert to silver top turbo. Just wondering if you have to change all wiring to the dash and a/c or is there just a connector from engine bay to interior wiring so its just the engine bay wiring and ECU that has to be changed? Thanks guys. Sorry this might sound stupid as you have already told how to do it but it just sounds way too easy lol.
Edited by sr_esky
theres a plug down in the passenger footwell where the engine loom joins the body loom. obviously different from 31 to 32 so you need to hardwire a few wires (tacho, temp gauge etc). theres a guide on www.r31skylineclub.com
or there is a guy named kev in r31skylineclub that mods the loom to suit your cars needs plug & play...
not sure on his user name tho.....
Cool, thanks guys. Have been looking at that site and they have manuals for rb30 r31's. Not to be a pain in the a hole but is the body wiring in the gtsx the same as the body wiring in a standard r31 4 door with rb30? Just different engine wiring from that plug?
give kev a call mate tell him what you want done & he will do it pretty cheap to :blink: his number is 0738144674
import is different but still the same procedure. the small brown plug down near the ecu is the body plug on the hr31 side, all the wires you need to wire up are in that plug
Thanks for that. Just wondering where kev is situated? Im in perth so if he is anywhere else then it might be a bit hard or does he supply pre-made looms or diagrams?
he is in brisbane but you could send your loom to him & he can make it you just need to send him a pic of the plug inside the car, just call him & work something out with him mate....
to do that you'd have to figure out which wires are which for him to make a plug, thats the hardest bit of doing it anyway. once you've figured that out you just solder them together and away you go. theres no diagrams or pinouts for the hr31 side of the loom anywhere on the net, you have to figure it out yourself or find someone whos done it before who can be bothered checking for you
as i said kev makes the loom so its plug & play
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
