Used Cusco Type MZ 1.5 way LSD for R34 GTT. I believe this will also fit straight in to a S15 (r200 diff housing) $1200
Used Cusco tension rod bar (strengthens front k-frame behind swatbars) $120 ono
Both items in excellent condition. Melbourne pickup preferred, or can post at your cost.
email [email protected]
From the web:
"Cusco MZ Type LSD, available in 1, 1.5 and 2 ways. The Type MZ LSD is most suited to the track, whereas the Type RS is suited to the street.
With the Type RS, the initial torque is absorbed by the RS springs therefore the initial torque comes on gently compared to the Type MZ which comes on stronger as it uses cone plates and response of the LSD is better, as the friction is lower.
*Lower initial torque *Lower power loss *Reacts well to delicate pedal work *Durable and develops initial torque steadily"
hey bud can you post a pic of the Used Cusco tension rod bar im not quite sure of what you mean i think you mean castor bar but different people call it different things. also not to shit can you or nothing but i think the diff price is way high as you can get 1.5 way diffs for round 800. but goodluck with sale. cheers
Prices are negotiable. If I don't get the price I want for it, I'll just keep it until i do. i have over $20k of other JDM parts I have sitting at home for my next car. It's no big deal to me.
Tension rod bar sits behind the front swaybar
http://www.rmsmotorparts.com.au/cgi-bin/Ho...tension_rod.htm
this will fit R34 GTT or R33 GTS-t (same model number)
skyline pdf of diffs
slivia and skyline PDF for diffs
Just thought i would post this up to help out anyone wondering if it will fit there cars.
I might be interested in the bar? i will have a think about it and let you know.
if the bar is not taken i will take it then. post to 2099 please. i guess it will fit 4 door GTT without a problem,right.. cheers
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
