Hey all, does anyone know for sure if the WRX STI 3.9 R180 LSD is the same as the C210 R180 open center, meaning a straight bolt up. There is one on ebay for $1000 and I'm wanting to buy one real soon. If not what is the next option ( easiest). Cheers
https://www.sau.com.au/forums/topic/276829-sti-diff/
you may be able to fit the lsd carrier to your crown wheel and pinion. but it will depend on bolt sizes. but as previously stated, check the usa forums.
ps Cameron... saw your missus driving from ipswich to morooka yesterday... she went past as i was leaving my driveway.....felt like i was staking her cause i went just one street past where she turned off. :) nice car once again...
reminds me of my old orange one......mmm
https://www.sau.com.au/forums/topic/276829-sti-diff/#findComment-4686067
hehe that's cool. Saturday you mean though right?? i was in the car too but was passed out in the front seat lol.
it sounds like you're ready to buy a C210 again mate. do it.
question: how much better is the Sooby diff compared to the r200? is it worth the hassle and price?
https://www.sau.com.au/forums/topic/276829-sti-diff/#findComment-4686255
Thanks Drew for hooking me up with the extortionist (joke), I now have a R200 LSD on it's way to me Yahoo!! I could also be buying a turbo supra box and housing tonight to put away for the V8 conversion ( it's over there in the distance) but it's getting closer. Got to sell my motor, $2500 bloody bargain. Interested anyone?
https://www.sau.com.au/forums/topic/276829-sti-diff/#findComment-4694307
  • 1 month later...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
